engine codes and diversion valve flutter
Old 02-01-2015, 06:17 PM
e90racer's Avatar
Default engine codes and diversion valve flutter
My recently purchased tt is showing a check engine light and occasional EPC light. My understanding is that the EPC light is the "engine power control" and it puts the car into limp mode, is this true? I only drive below 3000 and haven't noticed any significant loss of power.
I bought the car with a Neuspeed intake, unknown exhaust system, and forge diversion valve already installed. I believe the codes were caused by the exhaust. Is this normal for aftermarket exhaust and be cleared?
The codes that came back were:
-P1116: Faulty HO2 sensor bank 1 sensor 4
-P1136: Idle system too lean
-P0134: same as P1116?
Also, my Forge diversion valve is making a fluttering sound. This is my first turbocharged car and I found out today that the flutter is a sign of air flowing the wrong way. Is there a way to adjust this or will it need to be replaced?
I'm not sure if the codes and DV have any correlation. Hopefully tomorrow I'll have enough time to take a look at everything and check for vacuum leaks. Any outside opinions and/or help is always appreciated!
09Audi98
9
07-30-2018 12:43 PM
vtraudt
06-06-2017 10:20 PM
vw754
Q5/SQ5 MKI (8R) Discussion
07-11-2016 01:01 PM
I_love_my_car
12
01-18-2006 02:33 PM
ajp
09-24-2002 07:05 AM
Quick Reply: engine codes and diversion valve flutter
