Engine temp mystery:aftermath
Followup to my saga from yesterday. Thanks to all who helped out with suggestions. Turns out, it's the water-pump. So, I'm having the whole timing belt job done. I think we should figure in time as a factor that might override mileage. I'm at 44K but 4.5 years. If the water-pump is going, the timing belt couldn't be far behind. My extended warranty came in handy. I'll be out of pocket for about $500 which is a steal for a TB job at the dealer. There's a Sears down the street from the dealer so I'll pick up a battery right after I pick the car up. Any model number for the Sears International I should be looking for?
Thanks again.<ul><li><a href="https://forums.audiworld.com/tt/msgs/1587905.phtml">https://forums.audiworld.com/tt/msgs/1587905.phtml</a</li></ul>
I was in the same situation, water pump was bad and to do the timing belt, I ended up paying an extra $700 and some change, as they charged me for parts and for 1 hour labor... ouch.
it is the International....you could also go interstate, they are a bit cheaper at 85$ vs 110$ or so on the sears...
Sounds like a good price on the TB job..glad there is no permanent damage.....
The warranty only covered the "defective" part, the pump. The extra dollars are for whatever overage the warranty doesn't cover for the repair and the parts for the rest of the TB install.
The TT has had many different models of battery holders over the years. The differences are primarily in holes and tabs to lock in the base of the battery. You made need to file some areas of the battery's base to make it fit.
06B 109 119A Timing Belt, Continental same exact part as OE
06B 109 243D Timing Belt Tensioner, same exact part as OE
06B 109 477 T-Belt Damper w/included 06B 109 244 roller, same exact part as OE. (Has old part# 06B 109 479 stamped on it.)
06A 121 011T Graf or Hepu Water Pump with Metal Impeller (shown with magnet) and Exclusive Dieselgeek.com Water Pump Removal Kit (details at bottom of this page)
050 121 113C Stock 87 degree Behr German Thermostat with 059 121 119 o-ring seal. (Behr is OE manufacturer)
06A 121 121C Thermostat housing cover (plastic, replace every time you touch it!), same part as OE.
038 103 085C "Extra Coverage" DPH German Cam Seal X 2 (one for behind cam sensor, replace if leaking), better than OE
06A 260 849C Serpentine Accessory Belt, Continental, same exact part as OE
N 105 167 01 Always-Replace Small OE Motor Mount bolts x2 (torque: 30 lb. /ft. + ? turn)
N 102 096 03 Always-Replace Large OE Motor Mount bolts x2 (torque: 44 lb. /ft. + ? turn)
