ESP light - MAF problem Codes
Ok,i finally got the error codes from the Vag Com.
17963 - charge pressure max limit exceeded
16487 - MAF sensor (G70) signal too high - intermittent
Bad MAF?
As mentioned in previous threads, i have a newly installed Samco intake, 007 DV, and a K & N filter. Obviously, i have alot more air moving through. The K & N was factory oiled, so it should not be overdone.
This may be an unrelated problem, but i have noticed a slight hesitation sometimes at 3-3.5k rpms before the torque really kicks in.
Comments are very much appreciated.
Bad MAF?
The MAFs seem to be flakey but they might try to blame it on your K&N. I would switch to the stock filter just to be safe.
The other thing with the MAFs is that completely stock TTs seem to do okay with their flakiness. When you start to mod, you find out if your MAF is good or just okay real fast.
I have been pretty upfront with the dealership and they seem to agree the limited modding i have done so far are all upgrades.
I have made it known to them that i want to chip it, but first i want to get all the bugs out of the way so i can do a fair comparison with the revo vs the GIAC.
polishadonis
07-31-2005 11:02 AM
bigalk (back in UK)
12v V6 Discussion
14
04-02-2003 07:45 PM
