Fault code help
Fault code help
What does this one mean?
Address 08 -------------------------------------------------------
Controller: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00140
Shop #: WSC 01236
1 Fault Found:
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to B+ - Intermittent
Other fault codes I currently have, which will likely never, ever get fixed:
Address 15 -------------------------------------------------------
Controller: 8N8 909 601
Component: Airbag Front+Seite 1008
Coding: 10103
Shop #: WSC 01236
1 Fault Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
Address 55 -------------------------------------------------------
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00010
Shop #: WSC 01236
2 Faults Found:
01539 - Headlights Not Adjusted
35-00 - -
00776 - Level Control System Sensor: Left Front (G78)
31-00 - Open or Short to Ground
Coding: 00140
Shop #: WSC 01236
1 Fault Found:
Coding: 10103
Shop #: WSC 01236
1 Fault Found:
Coding: 00010
Shop #: WSC 01236
2 Faults Found:
35-00 - -
Der Kimbo
01-27-2005 04:50 PM
