FINALLY an end to my spacers saga!
So after 4 attempts to order H&R 15mm and 25mm spacers from various vendors, I have finally purchased Eibach ones from shox.com since H&R's are on backorder for the next 15 years. I don't wanna jinx it but they should arrive wednesday in time for my suspension install :-)
they said the eibach ones come with all necessary bolts...
but it just so happens that when I bought the H&R's which turned out to be backordered, I also ordered the 43mm lug bolts. so if I don't need the bolts I guess I will ship them back to evolutionmotorsports.
The bolts that come with the eibach spacers are for stock wheels >>
that have the rounded not conical seats. Looks like you have RS4 reps so you'll need conical seat 43 mm for the fronts (sounds like you're set with these).
For the rear - use the bolts that come with the spacers to bolt the spacers to the hub, then the bolts that came with the wheels to bolt the wheel to the spacer.
downunder
10-10-2008 06:47 AM
SporTTy
10
11-19-2006 09:50 AM
TTTEXAN
05-14-2005 09:47 AM
