forge dv flutter... which dv do i have?-->>
Old 02-24-2009, 01:46 PM
FijiTT's Avatar
Default forge dv flutter... which dv do i have?-->>
<center><img src="http://www.forgemotorsport.com/images/products/FMCL007P.jpg"></center><p>it looks just like the one in the picture, but mine doesnt have the flat spots around part that unscrews to open it up. its just round. it also says forge on it just like the one in the picture. its a rubber diaphram(sp?) and has the several springs that i can(i use the green one since im stock). i bought it second hand from a buddy with a 20th gti that was going stage 3+ apr. he cant remember which one it was.
ok on to the flutter.
it makes a fluttering sound as soon as i let off the gas and am at low boost(1-8 psi). it doesnt make the flutter if the car is in vaccum. Also it doesnt flutter at higher boost(10-15psi) instead it makes a whooosh noise.
is that how it is supposed to sound?
Old 02-24-2009, 02:07 PM
GorTT's Avatar
Default you possibly have an 007 and you need to open it up and clean and lube >
it (unscrew the top); also possible you have a diaphragm valve, that's more associated with fluttering, just that I'm not positive what it looks like and I do know the 007 looks like what you describe.
If it's a diaphragm, open it up and inspect for tears or fatigue.
Old 02-24-2009, 02:26 PM
AudiWorld Uber User
TTschwing's Avatar
Default It's a Forge DVR...You may have a ripped diaphram....>
Pretty common. Take it apart and look...Forge will send you a new part N/C
Some Forge's flutter on some cars no matter what you do..
Old 02-24-2009, 02:44 PM
HellooMcFly's Avatar
Default Does it look like this?
<center><img src="http://www.forgemotorsport.com/images/products/FMCL007PA.jpg"></center><p>
If it is then unscrew the top take out the o-ring seal and piston clean both. Re-apply grease and put it back in, make sure the top is tight.<ul><li><a href="http://www.forgemotorsport.com/valve_service.pdf">Detailed Service Instructions</a></li></ul>
Old 02-24-2009, 03:20 PM
joe@vwvortex's Avatar
Default Forge Race DVR - as Steve said - check the diaphram and also try a shim
under the spring and see if the flutter goes away.
Old 02-24-2009, 03:40 PM
FijiTT's Avatar
Default ok here is mine.
<center><img src="http://farm4.static.flickr.com/3301/3307207039_f9998b2c52.jpg?v=0"></center><p>
turns out there was a small tear in the rubber oh and i had a spare so thats good. what kind of lube should i use?
Old 02-24-2009, 03:41 PM
FijiTT's Avatar
Default second pic
<center><img src="http://farm4.static.flickr.com/3349/3308038066_e0976487fa.jpg?v=0"></center><p>
Old 02-24-2009, 03:44 PM
FijiTT's Avatar
i heard somewhere that you can reverse it? is it ok to do that? or would that even help?
Old 02-24-2009, 04:28 PM
AudiWorld Uber User
TTschwing's Avatar
Default Some Forge Units on Some cars flutter....>>
If there is no tear in the diaphram, not much you can do about it..
Old 02-25-2009, 06:32 AM
FijiTT's Avatar
what about fitting it in reverse. steve can you give me a mod blessing so i know its ok. ;-)
Quick Reply: forge dv flutter... which dv do i have?-->>
