Front Brake Caliper Torque Specs---Please ? NT
or thereabouts and you'll be fine. I've never used a torque wrench on them even when installing 996 Brembo calipers and never had one come loose. Just tighten by socket and give em a snug final effort and thats it.
These two pins per caliper have protective caps.
IMO: 40-50 ft-lb may damage the thread on the guide pin. Overtorquing to something below elastic limit of a threaded fastener usually does little harm, but if you yield the thread, especially near the shoulder, you risk complete failure. If we're talking of the same fastener, 250% overtorque is way too much, and will most likely damage the fastener. Some folks either over or under-guess what torque "snug" is to them.
No flames intended, but way too much torque is bad.
I haven't pulled the wheels yet to see what all has to come off. But I have done hundreds of brake jobs and wanted to torque everything back per factory specs. That is if Audi requires caliper removal to replace the pads. Installing Mintex C-Tech's for track event this weekend at Sebring.
TTigger
TTigger
am_ver
09-21-2009 10:02 PM
bingS4
06-06-2008 05:57 PM
CraigB
02-06-2000 08:02 PM
