Front bumper rebar removal - anyone tried it?
#12
I doubt it contributes to chassis stiffening since there are impact absorbers holding it to the
frame. If that safety bar was meant to add to stiffening, the impact absorbers can prematurely wear out - my 2 cents
However, it is defintely there for impact protection and safety. Perhaps you can replace it with a chrome moly piping of adequate size custom bent around your mod?
#13
Didn't know you were adding structural components...
Thanks for clarifying. Sorry to come across like an ahole. Those 5 mph parts can save your life not only through structural integrity but through material properties as well. Cheers!
#14
Yes >>>
I do realize that it is there for a reason. What I will replace it with is plenty strong.....
I spent a bit of time reading up on it, and it is basically there to absorb a bit of impact - it shears off the mount points fairly easily. However, at high speeds, I dont see it doing much.
And yea, I will be replacing it with something stronger and thicker. Probably not as impact-absorbing, but good enough. the 5-point harness should make up for any lack of safety
#17
it makes sense that it absorbs & dissipates the first few mph of energy>
even in a high-speed crash, so you are losing some protection in those in addition to the low-speed loss (presuming you weren't replacing it with anything).
Inyoury
A6 (C7 Platform) Discussion
07-01-2013 06:02 PM
Gray Bush
03-07-2007 07:34 AM
bluenote
10-18-2003 06:39 PM
