Front sway bar bushing size...2000 180q coupe
19mm or 21mm
If you have an early SN, you'll probably have 20mm ... later SN you'll most likely have 19mm ... but if you're FWD only, you'll probably have 17mm. I changed mine today and I had the 19mm work well after removing the bushing and the sleve that is glued to the sway bar. Easy way to tell is to crawl under the car and take a 19mm open end wrench and slide it over the sway bar aside the bushing. If it don't fit, try the 21mm just to make sure. The PowerFlex bushings I put in are available on-line and are part number PFF3-503-19.
the Quiet sTTorm...
10-23-2006 07:41 PM
mobsTTa
11-13-2004 05:11 AM
StormChaser404
12-24-2002 05:42 AM
