fuel air metering fault code p1176
P1176
17584
"Bank 1 oxygen sensor correction behind catalytic converter, Control limit reached
- Check oxygen sensor aging, oxygen sensor before catalytic converter"
A bit ambiguous (lifted directly from Bentley)... is it the pre cat or post cat sensor?
Ok, I get it now: when the front sensor craps out the ECU turns control over to the rear sensor... this code says the rear reached it's limit trying to correct for the failing front Ox sensor.
In any case it looks like a bad Ox sensor and typically you change 'em both anyway...
That's what I'd recommend...
17584
Heh! well, not necessarily... the first maf specific code my car "threw" took a maf AND a new pre-cat ox sensor to resolve.
More recently: a drivability problem (hesitations) with no codes:
the first new MAF.. no change
a second new MAF.. way better
(both were "remans" from ECS Tuning)
sorry this is less than helpful... codes and repairing these cars is not a precise science
well where is the best deal on the maf and the ox you think i priced out 400 for reman maf and new ox
front and rear. is reman ok for mafs
there's been a "run up" on the ox sensor's pricing recently... best bet: try a search on this forum...
reman MAFs are fine: it's a new sensor combined with a recycled holder
were failing and audi was giving a reasonable price on them but whatever.where is the pre-cat sensor? and how do you get to it?
thanks man
thanks man
<center><img src="http://pictureposter.audiworld.com/34314/charge_pipe.jpg"></center><p>
assuming a 225, remove the charge pipe (larger arrow) to gain access... the sensor is behind the cylinder head, below the pipe, it's connector is supported by a bracket attached to the firewall...
actually its a 180qc so i should be able to get to it from up top. thanks alot man youve been a big help. i just got the front sensor today so, we'll see how that works.
<center><img src="http://pictureposter.audiworld.com/34314/engine_code.jpg"></center><p>
If you do need to try a MAF, I recall interchangeability problems with some 180's... verify your engine code (the three letters stamped in the front of the cylinder head) against the MAF's part number... a "reman" may not work...
There are lots of knowledgable 180 owners on the forum, you might try another post asking for their input re the correct MAF
polishadonis
12-22-2008 06:46 AM
GinCQ
14
07-11-2008 09:29 AM
