Fuel Mizer
I have a stock 1.8L 225hp. I ran a tank of 87 gas through it the first time I filled it up. I could hear no knock or ping or detonation of any kind. This tank I ran premium. I can percieve no power difference between the two. What do you guys think of me just running 87 all the time?
I think 91 is the minimum on all models of TT. Run a few tanks of 93 through it & you should notice a difference.
the performance drop off was subtle, but running 87 is not a good idea for the long term. In a pinch, it will due....Some gas stations have 91, that would be the lowest i would go..
The TT is pretty good on gas....what is the purpose of running 87?
you can burn crap- its when you get on it and the boost goes up that higer octane would be called for. So much depends on how you drive- if spirited at all then you would benefit from higher octane, and isn't that what a TT is for? You should be getting mid to high 20 mpg so the difference in the 2 is negligable.
cooleddie
TT (Mk3) Discussion
28
06-07-2018 03:46 AM
Agent911
10-01-2002 08:35 PM
