Gasket is here.....
Gasket is here.....
http://www.newsouthperformance.com/gasket.htm
And I notice that in the instructions it says to use sealant to seal the new parts. I would rather us some thing that I don't have to worry about leaking..... Like maybe 2 of the OEM gaskets. Has anyone tried this? Or for those that have installed this gasket already have you had any problems with using just sealant?
Also I laid the gasket on my table and could tell that the gasket is not exactly flat. And I mean not exactly flat in a bad way. There is no nice smooth curve there are a few spots where it has a bit of a bend that doesn't follow the curve of the rest of the gasket. And this makes me think.... leak?.,.. Maybe I am overreacting and once the gasket is in place the manifold and head will straighten this gasket problem out.
super thanks.....
i planed to get the correct length bolts so i could use the insulating washers so i will remember to account for the 2 gaskets.... so how has your car been?.. you get time to start fine tuning it yet?
maybe if you were lucky...
my local home depot never has metric stuff in the size i need. i have a local shop that sales nothing but metric bolts and such..... just walk up with one of the existing bolts tell the guy at the counter i need the same thing but 13mm longer or what ever and he asks what grade... done... it rocks... bad thing is you have to buy a min of 8 buks worth the stuff per visit....
if you want i could get a extra set for you when i am there and mail them out i bet they wont be too expensive...properly 80-120 cents each..... (i know that is a bit much but they are Allen head and metric...)
mcmaster.com will have anything you need.
i think they are M6x1.25 bolts. i dont actually remember how long they need to be. remmeber, one or two of them are nuts too.
my car is doing well. finished up a lot of projects over spring break. on the dyno sometime next week or so
jbrentd
12v V6 Discussion
03-28-2007 10:24 AM
Ben's e//S2
15
04-30-2003 08:00 PM
