Gauge pod "peeps"....I'm thinking about getting Westach gauges.
These are nice because they will make custom dual gauges with black faces and red backlight. They fit a standard 2 1/16" opening and are 2" deep. I think that will work fine with thegauge pods that Chad is selling. JazziTT has these gauges and they look great!
I'm thinking about going with a dual oil temp/oil pressure and then another dual boost/EGT.
<img src="http://www.westach.com/images/showcase/2DC2-30-Boost-EGT.jpg" />
<a href="http://www.westach.com/products.htm#AUTOMOTIVE" target="_new">Westach gauges</a>
If you put the sensor in the turbo housing (best choice but requires tapping and threading) or the manifold (2nd best and requires tapping and threading) both of which will most likely require removal of said components, which may get a little pricey.
If you cheap out and only install the EGT probe in the downpipe (easiest and can be done on the car) it will not give you an accurate reading and will not tell you anything until it is too late and your turbo is toast already.
what are the limits of the EGT gauge?
that is, what does this read?
what's are the max. pressure readings for the EGT?
