Gave the car a try with the N75 unplugged, hit 5psi then climbed up to 10psi at redline>>
#11
my spark plugs are white and so are my O2 sensors. So my car thinks it's running rich, but is actually running extrememly lean?
#12
For a Vac leak possibly. Minus numbers are a rich CORRECTION based on a determination that the A/F , measured at the 02's and MAF, is too lean. Plugs and 02 are telling you that. Done the 02's yet? Vac leaks can be hard to track down and will not show up with a pressure tester. replace both the FPR and Combi valve lines as a matter of course. They're usually the first to go..
#13
to properly check for vac leaks? Just out of curiosity, don't those hoses get pressurized when doing a boost test? Also, any other hoses I should look at that aren't covered by the boost test? TIA!!!
#15
I can't seem to figure out where the hoses run to, any tips here will be great, thanks!
#17
pressure port hooked up directly to the wastegate actuator. So his test is appropriate - unplugging the connector. This is because the default state of the n75 is bypass.
I'm with Steve that it's somewhere in the wastegate or actuator.
Badd TT Bone
06-12-2007 08:14 AM
TTTEXAN
09-23-2005 05:18 AM
coasTTal
11-18-2004 03:37 PM
AudiTrio
12-01-2002 05:35 PM
