Gil (moblutt) i'm going to need to clear a code. installed the BM yesterday.
"A VAG-COM is also very useful. Occasionally, in your zeal for boost, you may cause an overboost code and the car will go into limp mode. In this case you've gone to far with your regulator adjustment."
But nobody reads them anyway.......:-)<ul><li><a href="http://www.modshack.info/bminstall.htm">http://www.modshack.info/bminstall.htm</a</li></ul>
they are the ones that reference the OBD and engine timing. you may want to double check the numbers. I've used it to clear limp mode before.
<center><img src="http://pictureposter.audiworld.com/24437/missed_a_spot.jpg"></center><p>Here were my choices: Work on 4 TT's, or fix the lawnmower.
Guess you can tell what won.
Gil can be swayed too, I bet.
