glove box wont open...any ideas?
I had that problem, the holding pins can be pushed open from the sides, remove the side panel that covers the dashboard on the pass side when door is open, then remove the bolted cover under it, you'll see a hole that aligns with the GB so push it with a screwdriver and that side should pop open, usualy this is the side that jams. Hope this helps
here..https://forums.audiworld.com/tt/msgs/1052297.phtml<ul><li><a href="https://forums.audiworld.com/tt/msgs/1052297.phtml">opening stuck glovebox</a></li></ul>
UKGAL
07-31-2008 07:17 AM
stevo_devo
01-24-2004 08:06 AM
Duke, 1.8T n Germany
10-30-2003 11:08 AM
