Good Morning MichaelTT! Question re: Audi center caps...
Noticed that I have basically 'copied' your entire wheel/brake/centercap, and valve stem cover scenario on your car. Only major difference is the state of cleanliness. :-)
With regard to the center caps though, did you glue yours inplace, or otherwise attach them? Mine seem a bit loose although I doubt they will come off, but it <i>could</i> happen and I want to secure them. Any ideas? Are yours 'really' tight?
BTW, the center caps I received from Clair had a circular metal ring that had to be removed in order to fit into the Sportec hub. Did you remove yours?
TIA!
TIA!
The center caps are actually a perfect match for the anthracite finished Sportec's.
As did a few others, including myself.
The tabs are good enough to ensure that the caps won't fall out, but the hot glue keeps them from rattling.
I think the center caps that you can get from Clair are slightly different. The ones from the OEM 5 spokes are made out of some alloy and have been priced out to around $50 a piece by another forum member. I think the one from Clair are about $10 a piece.
Hope that helps.
Hope that helps.
I'm running the identical winter setup and the lighter caps fit the Radons perfectly with the inner ring removed. Colour match is purrfecTT.
Stan (Toronto) See y'all in Asheville!
YumyJager
01-12-2004 07:59 AM
SteveTT
03-08-2001 02:30 PM
