Goose sounds
Goose sounds
Just purchased a 01 TT 225, it came with a Modshack intake. When ever I reach 0 on the turbo gauge I hear a goose like sound. I'm being told my DV may need to be replaced
- do you agree and would a good replacement be a OEM Audi TT 710N DV/BPV to solve the issue
- Lastly is this something I could do and how would I tell which spring code to use
does it sound like >
"AFLAK"? ;-)
Probably nothing wrong - do you know offhand if you have the oem or an aftermarket DV? On an 01 by this time you might have one that someone's swapped out to a bov or such.
As I told you on the phone Chris..>>
Honking is your stock DV. Hit the search above, type in honk, TTMK1 forum and see hundreds of reports on this. I have NO interest in misleading you..
Re: As I told you on the phone Chris..>>
Sounds like a common problem. Thanks again, going to order the stock OEM from TTstuff tomorrow. Seems it comes with four springs, how do you tell which one you need? Have you ever replaced one, something one can do on a Sunday?
