Got CEL, DTC 16795, Secondary Air injection incorrect flow..>>
Had this before, thought perished vacuum pipe fix on combi valve would fix it, nooot! What is the most common thing that goes wrong/fails with this system: Combi valve, solenoid valve or air motor or connections at one of them? Experiences?
I have Bentley instructions but what simple tests should I focus on first? I cannot get underneath the car easily.
Where is the solenod valve located?
not positive, but I think so. Dealer replaced secondary air injection pump under warranty. Not sure if that's the only fix. It's just an emissions thing when the engine is cold, I would probably just ignore it or see if I could trick it.
O2 sensor fail/incomplete (car was not at full running temp yet)
seconday air inj fail,
Catalytic conv fail
Catalytic conv fail
it can take several complete driving cycles to reset readiness code. By one complete driving cycle I mean engine completely warmed up, driving on the highway for dozens of miles.
You could use Vag com to more quickly set readiness code.
