Got new Rims , excel ennio.. 18' - question about hub ring and bolts to use
ok i currently have these rims mounted with the old bolts from the stock rims.. i heard this is not good and that i should use conical bolts? i have a set of new tuner bolts, will this be ok.. thanks
There are two types, ball and tapered (conical). You need to know which one the new wheels are, and you need to have them long enough to give you 8 full turns into the hub, too. If you are using the wrong type, the bolt won't seat in the wheel right, can wobble loose, and mess up the wheel at the least and come off at the worst.
Fig
Fig
shehatezme
02-27-2002 06:01 AM
1.8Steve
07-09-2001 07:24 PM
