Had my 30,000 service this week. Couple of questions and comments:
I had the problem with the 2nd to 3rd shift grind at high RPM's. I had heard that there is a new tranny fluid, so I asked to have that changed. Seems to have fixed that problem (so far).
Also, my brakes have been awfully sqeaky lately, so I asked to have that checked out. Here's what they wrote on the service statement:
Cause: Modify brakes
44051900 Remove and install 1 or 2 tires
46363200 Modify front brakes-cleaned and relubricate side points.
Front brakes at 60% and rear brakes at 50%. Still well above Audi specs.
This did nothing to solve the squeal. I don't even know if they did anything to the back brakes. They are just as noisy as before the service. Is there a TSB that addresses this problem? I've seen an "anti-squeal" spray... Has anyone tried this before? Is it worth taking off my wheels and calipers? That squeal is annoying as hell and makes my car sound like a piece of junk.
Finally, I got a "Free Track Day Inspection" and new wiper blades, without asking! What a deal...
Check transmission/shifting--hard to shift 2-3 gears at higher RPM's
Cause: Trans fluid change
34579999 Manual Transmission Synthetic Oil--Drain & Refill
2 G-052-145-S2 TRANS OIL
25,000 mile service showing I need new tires and brakes already--anyone else have similar experience
Julkiana
Q7 MK 1 Discussion
28
03-26-2011 09:59 AM
Black M3S4
01-02-2003 12:59 PM
