Have a p1476 but i did a evap delete how can i get rid of it
Have a p1476 code after i did the evap delete, i have all the resistors expect the ldp i dont have one for and plus its a 3 wire plug, i still have it plugged in and the code still comes up
Did you solve this issue? I have the same P1476 issue post Stage 2 tune with Evap delete. I placed all resistors (PCV also) even though they are not needed for the tune. All the Evap equipment is still in place.
You're not going to be able to eliminate all EVAP codes by adding resistors. The EVAP system measures pressure of the fuel fumes to detect for leaks and without properly working EVAP components (vacuum pump, sensors, valves, etc) you are going to have codes that will need to be tuned out by an ECU tuner.
Visti
Canadian Discussion
15
05-06-2024 12:47 PM
Stink
09-14-2020 01:47 PM
