Hazard Relay.
Hazard Relay.
I just read SparTTan's instruction on replacing relay. Great point by point instructions.
I just had the dealer replace mine becuase is was acting weird. Do they install a better version on the relay in the car? or is it just a New relay that go bad again?
Same part, can't replace the "relays", they are all part of the assembly
Each relay here controls one side of the car.
Both relays switch when the Emergency switch is on.
<img src="http://uh.clem.home.comcast.net/images/emerswitch.jpg">
well, he asked specifically if the *relay* can/were replaced, so my answer still is no....
In fact, it's not the "relay* at all that goes bad, it's the electronic circuit that *drives* the relays.
the unit I have still works fine, if you drive the relays with a different circuit.
Unknown. Perhaps Audi "fixed" the circuitry, and just cut-in the new models using the same P/N. this
is typical.
check the revision letter on the board assembly of the new switch.
MXHowes
04-28-2009 05:26 AM
scottbess
06-21-2008 03:54 PM
