Heading in for 20K service this AM... Q - What is best grade of synthetic oil?
Thank you for your inquiry.
Most car manufacturers recommend 5W-30 or 10W-30 grades for normal driving conditions. Improved engine technology with tighter piston ring and cylinder wall tolerances allows the use of a lower-viscosity oil with-out increasing oil consumption. (A "loose" engine - or one with wide tolerances - allows too much oil to get past the piston rings and into the combustion chamber, where the oil is burned along with gasoline.)
We recommend that you follow the engine manufacturer's
recommendations as indicated in your owner's manual. For maximum
low-temperature performance and maximum fuel economy, use the lightest
recommended oil viscosity. Heavier oils can impede engine starting,
lower fuel economy and steal horsepower.
Thank you for your interest in Mobil products.
The above information is provided in good faith based upon the
information presented by the customer. ExxonMobil is not responsible for
any loss or damage resulting from inaccuracies or errors in any of the information provided or any acts or omissions taken in response to our advise.
I believe our TT manual recommends 5W30 or if not available, then 5W40.
OTOF
09-29-2001 07:49 AM
WagonBoy
09-10-2001 08:38 AM
S4_Obsessed
05-22-2001 06:35 PM
Skydive69
15
05-21-2001 03:12 AM
