HELP,(225TT) , Bought two new MAF 06A906461A , but engine light still on?
I bought two new MAF 06A906461A, but my engine light still on and limp mode, it is I buy the right one, or it is different part number for 225 TT, I see the insert have a little different than my oem
the fault code will have to be cleared by a VAG-COM or similar. but sounds like you have other issues, not the MAF. maybe you should check your coil packs...they usually put the car into limp mode.
I have reset the CPU, and clear the code by VAG, but I think is the 2.0 MAF is different than the TT 225's MAF
have you checked to see if your maf is plugged in? You said that you reset the ecu? How did you do that? Did you go into blk 060 in Engine - Basic Settings to do a throttle adapt after you cleared the codes?
Greyhaven7
11
09-26-2007 11:57 AM
black225TT
10-17-2003 05:25 AM
