HELP...again and marry friggin x-mas
I have three codes and the throttle body won't adapt. The values in Vag just keep reading 97% and 98% for throttle body adaptation.
Here are the codes:
17952 Angle Sensor 1 for Throttle Actuator Signal too Large
17581 Angle Sensor 2 for Throttle Actuator Signal to High
Here are the codes:
Both of these sensors are located in the throttle valve control module
"Angle sensor 1 for throttle drive (power accelerator activation) -G187- and angle sensor 2 for throttle drive (power accelerator activation) -G188- inform the Engine Control Module (ECM) about the position of throttle valve. Both angle sensors are located in throttle valve control module".
I think this means your throttle body.
There's extreemly high spring tension, a stepper motor, the sensors, other parts. You might try flushing it out...
Squeeto
15
08-10-2022 04:11 PM
thewatcher101
06-18-2008 10:44 AM
DrewP
10-13-2003 06:20 PM
