HELP !! - Dumb V1 install question
As most of you know, I'm not that good at installs and stuff, but I try
Hardwiring V1 in Joyces allroad - The V1 turns on for a few secs then turns off ???
What have I done wrong ?? I tried several fuses and also a direct connection under dash - I am confused
I have grounded to a screw underdash that is painted yellow (I think that means its the place to ground ?)
Thanks for any help !!
just the TT. It will have about a dozen or so brown wires coming to a single bolt. In the TT it also have a plastic ring connected to it to guide the wires in.
Does the unit remain on when using the cig adapter?
What did you use for the positive? It is possible that one is not connected solidly. Check it out as well.
I switched remote displays with the one from TT and it worked fine - put the new on in TT did not work - Defective remote !!
Thanks for your help - have fun skiing
DirtMonkey_NWB6S4
05-22-2003 09:11 AM
Duffer
05-17-2002 12:56 PM
tall6guy6
Performance and Tuning
02-10-2001 03:57 PM
