Help!! electronic woes....
Old 05-30-2005, 05:12 AM
  #11
Junior Member
Neo1130's Avatar
Default Did you measure from terminal to terminal on the battery? Or from + term to ground?
Because you can get a reading also of 9.3V if your ground cable is messed up if you didn't read straight across the battery... The reason I ask is because alot of people actually measure that way...
Old 05-30-2005, 08:04 AM
  #12
MCPaudiTT - DEFCON 1's Avatar
How old is your battery? It might be it won't take a charge, and your alternator could be fine...
Old 05-30-2005, 02:33 PM
  #13
Member
zenmasTTa's Avatar
Default except that it wouldn't have been an issue while the engine is running right?>>
I don't think a bad battery wouldn't account for everything shutting down while driving. I think the generator would account for that...
Old 05-30-2005, 02:36 PM
  #14
Member
zenmasTTa's Avatar
Default We measured voltage using TTagz's technique....see above
we didn't have a voltmeter handy
Old 05-30-2005, 02:39 PM
  #15
While that is traditionally true, the TT seems to be very finicky...
Old 05-30-2005, 02:59 PM
  #16
Member
zenmasTTa's Avatar
true dat - need a special manual with all the tricks
KtrainHurricane
11
05-11-2017 07:52 PM
Audimobiles
05-08-2008 08:35 PM
banal
11-12-2006 07:40 PM
Egil A64.2s - S6
06-12-2002 12:46 AM
geiswiz
12-08-2001 02:40 PM
Quick Reply: Help!! electronic woes....
