Help!!! Hard Start
I have a 180t fw. It has a problem I haven't been able to diagnose. Everyday when I start the car for the first time it doesn't want to start. Ill try and try and eventually it does start but then it rough idles for about 5 mins. Then everything runs fine for the rest of the day even when i try to start it at the end of the work day. This only happens in the morning. Anybody else have this problem or any ideas. I tried replacing the fuel filter and had a diagnostic run on the entire fuel system and everything checks out. The car isn't even throwing any codes. Its just angry in the morning.
What should I try next?
![Mad](https://www.audiworld.com/forums/images/smilies/mad.gif)
hehe coffee didn't work. I replaced the ctp. I replaced the fuel pump. It says everything is fine after the OK symbol comes up. Could is be the throttle position sensor?
hehe coffee didn't work. I replaced the ctp. Fuel filter was replaced.This morning I waited until it said "ok" tried it, and no improvement. Would a failing fuel pump throw a code or give me problems even after starting? What symptoms would I see with a busted throttle position sensor?
wallaceno1
22
10-09-2008 05:13 PM
audi/s/scott
16
12-18-2006 01:01 PM
Catamount90
12
04-21-2006 09:23 AM
Audi200T5000S
04-02-2003 12:47 PM
