help me decode my codes?
I went to the Newington GTG on Thursday and â€oesome guy” with a Vag-Com scanned my TT and it came back with the following:
Address 01: Engine
Controller: 8N0 906 018 T
Component: 1.8L R4/5VT G 0003
Coding: 06610
Shop #: WSC 01236
2 Faults Found:
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
18056 - Powertrain Data Bus: Failure
P1648 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8N0 907 379 C
Component: ABS/EDS 20 IE CAN V003
Coding: 13504
Shop #: WSC 01236
2 Faults Found:
01312 - Powertrain Data Bus
37-00 - Faulty
01324 - Control Module for All Wheel Drive (J492)
49-10 - No Communications â€" Intermittent
Address 22: AWD
Controller: 02D 900 554 B
Component: HALDEX LSC ECC 0006
3 Faults Found:
37-00 - Faulty
01316 - ABS Control Module
49-10 - No Communications - Intermittent
01314 - Engine Control Module
Please give me an idea as to what is going on ????
Thank you,
Address 01: Engine
Coding: 06610
Shop #: WSC 01236
2 Faults Found:
P1648 - 35-00 - -
Coding: 13504
Shop #: WSC 01236
2 Faults Found:
37-00 - Faulty
Address 22: AWD
3 Faults Found:
37-00 - Faulty
Thank you,
