Help. MY xenon is blinking..i just put everything back after i took of the lights to paint.
only one is blinking. Could thei mean low voltage...(i did also put in pulleys today)
But i am sure it is the ballast b.c i swiched ballast and then the other one was blinking...do i need a new ballast or has the have to do with voltage.
thanks guys
thanks guys
my guess is that if it wasn't happening before you did all of this, you may have screwed something up or the electrical system isn't happy with the underdrive pulleys that i'm sure you were warned about (if those are the pulleys that you're talking about)
no the car so it is probably just the ballast on that headlight that was installed today. I am 99% sure its the ballast but i am wondring if this has happend to anyone else?
If you say you switched ballasts and it causes the other light to blink then you have isolated the problem to that ballast. What temp did you have the oven at?
adammorley
10-17-2001 07:09 AM
