Help, no electrical power at all on the 2000 TT
Long story short, I drove to work just fine, and parked. Came out less that 6 hours later and the FOB didn't open the door. So I manually unlock it and no dome light. I turned the key and nothing. No crank, no dash light, no horn, etc. I didn't leave my headlights on, but even if I did I should have at least minimal light.
I had a friend jump me, but I didn't think it would work and it didn't. Still absolute zero in terms of any power at all, not even a dome light. Terminals are tight and clean, and the battery is from December. I'll check it out in the morning. Any suggestions? Not sure what could have happened. I did install a mirror camera directly to the battery last month, but it is a very slow drain. I start the car every day just fine.
Troubleshoot and diagnose voltage from the battery to the starter and fuse/relay panel.
Good luck with it.
Simple troubleshooting techniques apply here. Did any lights come on while you attempted to jump start the car? If not, figure out why. What ground or positive cable from the battery corroded away or somehow broke? How do the fusible links above the battery look?
Good luck with it.
Good luck with it.
Definitely not a good idea to connect any gear directly to the battery. These cars are especially sensitive to electrical energy drops.
Connect with a remote fuse and switch to ensure unit cannot draw any parasitic load.
J@RO
Audi 100 / A6 (C4 Platform)
12-29-2008 06:53 PM
Guilty
09-02-2005 05:15 AM
