Here is what I found on Mobil 1's website(GOOD INFO!)[BZ maybe add this to the FAQ?]
Quote from the page about 15W-50:
"Mobil 1 Tri-Synthetic Formula 15W-50 is especially suitable for high-performance cars, particularly hot-running or heavily loaded vehicles and special high-tech imports."
Flash Point, ASTM D 92, °C (°F):
0w-30
238 (460)
5w-30
235 (455)
10w-30
243 (470)
15w-50
245 (473)
Flash Point, ASTM D 93, °C (°F):
0w-30
211 (412)
5w-30
210(410)
10w-30
221 (430)
15w-50
223 (433)
5W-30 has the lowest flash point of them all(bad). 15w-50 has the highest(good). Seems to me like 0w-30 would be better to use before 5w-30
Here is Mobil's comparsion of the 4 types:
Mobil 1 Tri-Synthetic Formula 0W-30, 5W-30, 10W-30:
Flow at -54°C (-65°F); pump at temperatures lower than similar SAE viscosity-grade conventional oils.
<B>Save gasoline, exceed newest Energy Conserving Requirements.</B>
Mobil 1 Tri-Synthetic Formula 15W-50:
Flows at -48°C (-55°F), pumps at temperatures as low as many conventional SAE 5W-30 oils.
<B>Provides superior high-temperature protection for high-performance and high-revving cars.</B>
(Looks like I can run 15W-50 all year round)
All Mobil 1 Tri-Synthetic Series products:
Provide outstanding protection of gasoline, diesel and turbocharged car and light truck engines.
Provide excellent engine protection during high-temperature operation.
Extend engine life by reducing wear.
Allow faster cold starts.
Help prevent oil breakdown; keep engines cleaner.
Are compatible with conventional oils.
Provide maximum reserve capacity in a motor oil.
Reduce oil consumption.
I hope this helps people understand which oil is the best for them. I know it confirmed what I thought.<ul><li><a href="http://dallnd6.dal.mobil.com/GIS/MobilPDS.nsf/26b7c4b33367a4a086256665004e4266/9337c5cedcf5e32e852567b60056db77?OpenDocument">Tri-synth info page from Mobil1.com</a></li></ul>
0w-30
238 (460)
5w-30
235 (455)
10w-30
243 (470)
15w-50
245 (473)
0w-30
211 (412)
5w-30
210(410)
10w-30
221 (430)
15w-50
223 (433)
Dave Griswold
06-26-2002 06:17 AM
mmms4
04-19-2002 06:53 PM
2dinos
04-27-2001 12:30 AM
Howard
04-15-2000 01:51 PM
