Hiya guys! Feedback appreciated on H&R springs as replacement to PSS9 rear ones. Pic inside...
<center><img src="http://img.villagephotos.com/p/2003-9/395369/dsc00846.jpg"></center><p>First of all, thanks to the unknown member who took this pic!
I just bought a set of these H&R springs to replace the PSS9 ones that have completely collapsed. I was only wondering whether I can mate them to the PSS9's height adjustment plate at the rear. Anyone tried that? Also, these springs seem a heck of a lot stiffer than the PSS9 ones, anyone care to comment on the suspension's comfort after their installation?
TIA!
TIA!
Eighth Member of AudiWorld. God-like, glorious and all-knowing.
My gut feeling is that it would work just fine, as the H&R spring is (I believe) a direct replacement for the same rear spring that is on the Bilstein coilovers. The springs for both coilovers are made by H&R, I do believe.
but I would imagine that you are going to have a heck of a time adjusting the rears with the increased tension. Did bilstein not issue a new rear spring yet? You should get the full refund while you can. Get back labor costs as well.
for HUNDREDS less. No headaches, and just the feeling that your car is properly setup.
Lesson learnt.
Anyway, I'll try the H&R spring and post back my impressions. Hope this doesn't turn into an adventure, but from what I understand I should either expect my teeth to fall off after the first speed bump or the body shell to shear in half. Great!
