Hotchkis sway bar update>>>
Old 01-04-2005, 08:23 AM
  #11
ArTT Vandelay's Avatar
Default I don't trust hollow, h&r has multiple pick ups, and they have the carbon liner thingy
that doesn't require lube. That said, I'm using Neuspeed and have been very happy. no squeaks that others speak of. I may upgrade to the h&r, simply because it's a thicker bar. then I'd get the matching front too.
Old 01-04-2005, 08:31 AM
  #12
Elder Member
kodeTT's Avatar
the carbon liner sounds interesting...what's the sizing for the front/rear combo?
Old 01-04-2005, 08:35 AM
  #13
Elder Member
CusTTom
Trust hollow.... it is stronger than solid... gotta be an engineer here to explain it.
Old 01-04-2005, 08:38 AM
  #14
Former Vendor
MikekiM@PureMS's Avatar
Default Further update
Camber plates are coming soon as well for the TT.
Visit our website for details.
Old 01-04-2005, 08:39 AM
  #15
Elder Member
CusTTom
Default Everything will require lube.. or it will wear eventually.. the H grease fittings are
awesome since at every oil change it's SO easy to do.
Thicker is not better.. adjustable is better... fully adjustable endlinks would be nice.
Old 01-04-2005, 08:43 AM
  #16
Elder Member
CusTTom
Default From you or Hotchkiss? When I spoke to them (wow.. a YEAR ago now) they said that was part of their
development plans.
Along with adjustable links, etc.
Old 01-04-2005, 09:20 AM
  #17
Former Vendor
Default H-Sport
They've had prototypes for over 6 months now. ON display at the 1.8T Challenge on their entry GTI 1.8T.
They're scheduled for production this first quarter '05.
Old 01-04-2005, 09:52 AM
  #18
Elder Member
CusTTom
Awesome.. thanks for the heads up.
Old 01-04-2005, 10:34 AM
  #19
Senior Member
TTagz's Avatar
Default so if it is a 19mm bar and adjustable...
then its max setting would be similar to that of the fixed neuspeed bar. Why wait for hotchkis? I ould see waiting if it were a larger bar with adjustment, but not for the same as what is already out there.
Old 01-04-2005, 11:49 AM
  #20
Elder Member
CusTTom
Can't go by diameter alone... the end links, construction, etc...
Quick Reply: Hotchkis sway bar update>>>
