How To Achieve Smoother Shift From First To Second Gear?
It seems like no matter what I do I can't achieve a smooth shift from first to second. I have no trouble shifting from any other gears. The only way I can achieve a smoother shift from 1st to 2nd is when I shift early or let the rmp go down between 2000rpm-3000rpm by that time I will be losing some speed and ending up slowing down. Does anyone have any advice or mods I can do to remedy this problem? Any help will be much appreciated.
I have the same issue...
I found it works best for me to shift between 3000 to 3500 rpm. Any lower or higher and it's a rough shift. I'm still trying to figure it out, but it also seems to help to apply slight pressure to the gas while letting out on the clutch.
A couple of things you can do....>
That 1-2 shift can be a little rough. Several things can improve it though...Boost transition is a little awkward...Upgrading your DV can make that smoother (and a **** will make it smoother still). Also installing a set of $16 energy suspension poly bushings in the Dogbone will reduce the engine movement as torque application changes and make for a smoother shift. Redline fluid and a careful linkage adjustment will help a bit as well..
