How to add/change power steering fluid
<center><img src="http://i5.tinypic.com/2d1p6hv.jpg"></center><p>Hi all, i would like to change/add power steering fluid to my TT. I have bought the fluid already and can anyone tell me the procedure.
Also, can anyone tell me how to open the green cap that show on the above?(It was in red circle)
Thank you all
Thank you all
If you want to actually change it, that's a more involved procedure. There is no "drain" per se, but you can easily pull the hose off the bottom of the power steering pump underneath the car and the fluid in the reservoir will drain out.
However, you will still have some fluid in the lines and the steering rack. It is a little more involved to flush that out.
larsenracing
11-12-2014 04:06 PM
mxp
06-26-2006 02:57 AM
