How do you get rid of that annoying whine inside the car? I've heard its alternator whine....
Old 06-24-2003, 02:14 PM
New Member
maru's Avatar
Default How do you get rid of that annoying whine inside the car? I've heard its alternator whine....
but can't find a fix in the forums
Old 06-24-2003, 02:32 PM
Member
christopherjs's Avatar
be more specific please
Old 06-24-2003, 02:51 PM
New Member
maru's Avatar
Default I really don't know how to describe it better....
When I turn on the headlights, you hear this whine sound....regardless whether or not the radio is on.
I've heard it is a common problem
Hope thats more specific
Old 06-24-2003, 02:59 PM
msauve's Avatar
Default Does it go away if you turn the instrument dimmer to full bright?
There was a service bulletin, where some instrument clusters (through 2001?) would make a noise if the lights were dimmed at all. Audi will replace the cluster with a new one for this if you're still under warranty.
Old 06-24-2003, 03:04 PM
Member
Default I believe a new headlight switch should fix the issue >>
For now, if you put it on fill brightness it shouldn't buzz. I found some threads that said replacing the instrument cluster fixed the problem, but this one I linked to says just the switch needs to be changed.
Can't say for sure if that will fix it, but that's what I read.
I don't have the issue in my car so I assume whatever was redesigned was done before June 2002.<ul><li><a href="https://forums.audiworld.com/tt/msgs/163557.phtml">mine was fixed..</a></li></ul>
Old 06-24-2003, 03:06 PM
Member
Well, either way (switch or cluster) it seems Audi does have a fix for it.
Old 06-24-2003, 03:13 PM
CartoonDog's Avatar
Throw out your girlfriend?
Old 06-24-2003, 03:15 PM
|everso!|'s Avatar
raaahaha
Old 06-24-2003, 03:27 PM
Lloyd of the Rings's Avatar
Very good!
Old 06-24-2003, 05:44 PM
RoninTT's Avatar
Yeah, and if you're like me and not under warranty, leave the dimmer on full bright!
Quick Reply: How do you get rid of that annoying whine inside the car? I've heard its alternator whine....
