How many mAh are supplied by switched 12V sources (like the fusebox?)
Power requirements are minimal (most have led lighting and are tapped off the blue dimmer line) To answer your question, look at the fuses to determine the max Amps on that particular circuit
A wire that has a 5A fuse on it, can omly support and sink something on the line that does not exceed that fuse rating.
Your gauge should not draw more than an amp, depending on the gauge.
Like will an oil temp gauge run on less? I am doing an unrelated project where I will need to run an automotive water temp gauge on a DC circuit, not in a vehicle, and on less than 12V. (possibly 6 if I can get away with it) In modern aftermarket temperature gauges, besides the backlight, what is being supplied with power at 12V? a potentometer?
Bob W.
04-10-2003 08:38 AM
