How much does the 100 Octane APR program add over the 91/93? I have only seen dyno charts for 91/93
I have an APR 93/100. I was told that the gains from the 100 are more from the program bumping up of he timing. Now if that's true and I run a Boost Machine with 100 octane mode do I have to run lower boost then the 93 mode??
Guys have said that running an aggressively adjusted Boost Machine on 93 is very similar (without the $5 gal. penalty). Dyno's I've seen on other VAG cars, factoring solely for boost, indicate 1 psi is good for about 5 hp...
YMMV..This was on an A4 motor
the timing advance w/100 creates a nice, high strung feel to the motor, unlike just more boost that usually tapers off well below redline.
The 100oct mode feels more like a sports car...less like a muscle car / truck
Banned
110 OT fuel is standard Avation fuel, and is much less expensive than if you purchase "race," fuel.
Expect to pay .50-1.00 more rather than $5.00 a gallon.
Avgas is leaded...<ul><li><a href="http://www.chevron.com/products/prodserv/fuels/bulletin/aviationfuel/7_ag_intro.shtm">http://www.chevron.com/products/prodserv/fuels/bulletin/aviationfuel/7_ag_intro.shtm</a</li></ul>
Banned
the amount of lead in Aviation fuel is not significant enough to worry about for "track days," once in a while.
You're not going to fill the tank with 100 OT "race," fuel at every fill up so you can run the 100 OT program all the time. It's a setting that has it purpose and is used sparingly between "normal," driving and track driving.
