How much should it cost to do an Alignment at Audi? Can a VW dealer do it? Is it Cheaper at VW?
First time: alignment rack broke, I went home without alignment done.
Second time: all appeared Ok until I read the printout later at home -- they hadn't touched the rear camber because the machine hadn't flagged it as bad, but one wheel was way out of spec.
Third time: I had them redo the rear camber it on their own dime; this time the rear camber's good, but it looks like the front toe is a small bit out on the right side... hopefully an artifact (because I don't think they touched the fronts)
<b>Verdict?</b> I'll go to an independent shop next time.
BlownHeadlight
9
05-15-2004 07:38 PM
