how to replace clutch pedal switch
Does anyone know how to change it, this CEL is getting annoying, or a part number?
is it near the brake sensor above the brake pedal?
i had a clutch pedal switch cel a while back and i cleared it and it's been 3 months and 2000 miles and it hasn't come back on. i'm assuming (and some people on here also agreed) that if it was a real problem it'd come back on within a few minutes/miles.
from what i've read on here, the switch is a safety to prevent the car from starting without the clutch depressed, so if you can't start the car up without the clutch, then it shoudln't be a real problem. but yes, it's down there near the brake sensor and i've heard it's real easy to replace, but that's as much as i can tell you. good luck.
Clutch starter inhibitor switch maybe (part#1j0927189c) which is $45.16
He also mentioned a Cruise control switch (part#150927189f) = $36.18
Brake switch (1j0945511e) - $17.00
But i start the car normally, I have to push the clutch down.... hmm
are you gona try any of those or just order the parts? they're much less expensive than i thought they would be, i didn't look into it since my code never came back
Trango
Audi allroad
10-31-2007 06:22 AM
B5QShip
11
02-19-2007 08:10 AM
AudiSport4000
10
11-11-2003 05:24 PM
