I am having problems with my Top
2009 TT roadster.
My top will go down but not up anymore.
The side doors are ok and open and close properly.
The dealership says I need 2 new motors? If it goes down aren't those motors OK. How can 2 burn out at the same time? Those types of motors are protected so the chance of any 2 going at the same time is impossible.
Any ideas? Fuses etc. Just could be out of sync with the sensors?
Thanks so much.
Thanks so much.
You have a Mk2 Audi TT, this is the Mk1 forum. The Mk1 top is actuated by a single motor turning a hydraulic pump that attaches to 2 hydraulic cylinders. Sounds like yours uses 2 electric motors? Regardless, if the top goes down but not up the motors are probably fine. I would guess the likely culprit is one of the sensors/switches that prevent you from closing the top inadvertently. The Mk1 has switches for the cover that goes over the top when the top is down. If these switches are damaged that would prevent the top from going up. There is also some logic in the car to prevent you from closing the top while the car is moving, that could be faulty.
In the Mk1 the fuses and relay (called a "control module" in the shop manual) for the top are in a relay panel under the steering column.
I know that in my mk1 you have to be at a full stop. I know in my 2013 a5 you could go at slow speeds and still close the top. Also, are our windows inching down when you engage the roof? If not, the roof will not budge.
DirtyVegasTT
06-17-2004 09:04 AM
Matt Daniels
Events Discussion
11-20-1999 12:05 PM
