I have a seized lug bolt... now what!?
Sheesh... nothing is ever easy. I tried to paint my calipers today but encountered a seized lug bolt. I broke two sockets before I took it over to my local tire shop. The shop guy spent 2 hours stripping the head... which is now basically round.
What should I do now!???
Have "Bolt outs" that, when used with a highpower impact, can get those out...
These can grip a rounded off head, provided they're skinny enough to get into the wheel lug hole..
First one was 350 ft-lbs of torque and the other was 500. Both of them broke. And as Steve mentioned, they were using bolt-out sockets for stripped heads.
Took it to the dealer. They let it soak with penetrant for an hour or so, and then according to the service manager, "forcibly coaxed it out."
I would say try soaking it with PB Blaster. This is the best penetrant and you can get it at Autozone. Then you need a high powered impact wrench and one of the bolt-out stripped thread sockets. (Sears makes them for impact wrenches.)
Now I use anti-sieze every time I remove my lugs. I recommend you do too. Imagine if this happened when you had a flat tire in the middle of nowhere!
ITALSKIER
12-21-2003 07:21 PM
BrianN
10-12-2003 09:38 PM
