I heard a belt squeal yesterday.
Probably the serpentine belt that drives the power steering/alternator. Could be the tensioner going bad too, two reported recent failures on here.
If it would fail it wouldn't hurt anything, you'd just lose power steering and your battery would die forcing you to fix the issue. Repair is a lot easier and there's nothing there that can damage your engine if you happen to do it a little bit wrong like a timing belt.
winter slumber for a quick trip in the sun. It made a bad squeal which temporarily went away when I turned off the heat. It came back an hour later as I pulled back into the driveway. This time it was nasty sounding and maybe even a bit of grinding.
I'm going to pull the plastic covers and see if I can find the source. If not, I'm getting towed to the indie shop Monday.
Related question. I'm having my timing belt, tensioners, and water pump replace Monday for about $850 including OEM parts. The water pump will be a metal impeller. No thermostat included. Does that seem high? Labor is about $400.
thanks
Rob
thanks
Rob
Sal R.
08-19-2007 11:47 AM
cmissle
10
01-14-2003 08:39 AM
