I just completed the TTschwing-DV Mod. - Wow!
I have the Forge valve with the updated alum. piston.
Boost is a lot more linear and stays on hard through 6K.
My valve interior was dirty, and a good cleaning and re-lube no doubt helped, but this is noticeably different.
I need to drive more to see how much better.
The washers were slighlty larger diamenter, and I had to grind them down a bit.
We can do yours in about 30 minutes.
The hardware store is down the block.
Great Jeff! Glad it worked for you too. The mod makes perfectly logical sense of you're running the 006. I'll slip ya the $.16 (for the testomonial) next time I see you!!
Steve
Steve
