I need a vag.com
You only get the full use with the Vagcom cord and then it is not the 409 version it is the 908 version. Get the USB corded version from them and you can use the full version and do much more with it. And the version with the Keycom interface is $249
http://www.arlab.it/vc/main.html
If you're looking to do basic stuff, it will clear check codes, etc. It works from a pocket PC. I used an older IPAQ, so it boots up immediately.
I would like to get a Hex-USB+Can so I can have full function plus be able to use it on the newer audis should I decide to get one. I'm just not ready to part with $350 for what is now just a nice-to-have
Audi Other Ross-Tech VCDS VAG-COM HEX-USB+CAN Interface
brents
01-09-2017 08:21 AM
