I want to get clear corners but how do I get rid of the other orange marker inside the headlight?
<center><img src="http://pictureposter.audiworld.com/72891/dsc00317.jpg"></center><p>How do you get rid of this other marker inside of the light...do they make a clear marker for those or do they pop off or what?
is tough but get a strong hair dryer and have someone help you. You will really need to heat the entire crease a bunch prior to pulling them apart. Once you start getting housing apart keep heating in areas and will come apart easly. Dont worry when you put them back together just as hard to get apart again. The orange lens just pops out and you put risos clear in. There are clips that hold the clears in so be careful not to break them. Here is a link..Click on clear corners then install<ul><li><a href="http://homepage.mac.com/risowu/OSIR/TT_HEADLIGHT_HOME.html">http://homepage.mac.com/risowu/OSIR/TT_HEADLIGHT_HOME.html</a</li></ul>
housing. no marks on front side, just heat weld marks on the back. Dremel the 4 spots on the back and the reflector will just pop off.
