I would like to listen to Pandora on my iPhone through my
stock head unit. Is there a way to add an aux input to the back? Is there a harness, or something that would allow me to turn the CD changer input into an aux? I like how the Dice, or peripheral, set-ups have the one cord that plugs into the bottom to charge the phone, but I think that I can only play the ipod application from the phone.
Any experience or ideas is greatly appreciated. I searched but couldn't find any threads that addressed this specifically.
Thanks, Chris.
Thanks, Chris.
i dont have an iphone but my friend put hers in my car and it worked...
if you dock your iphone in speakers does the pandora app play? or only through the headphone jack?
Not sure about the 3G (which I have now). I think I've read reports that it works fine - and other reports that it doesn't. Someone else will have to comment on that.
I'm not sure if Pandora plays audio through the Dock Connection though.
the dock, bottom, of the phone when using it as an ipod. But I don't believe the Pandora application will work. My wife has a Toyota HIghlander with an aux jack that we plug in through the earphone jack, top, of the phone. I was wondering if there was some way to have this same set-up through the back of the stock head unit.
on the back of the headunit. I've bought stuff from Christian @ Enfig - good company to deal with.
<center><img src="http://pictureposter.audiworld.com/11/source_selector_1.jpg"></center><p><ul><li><a href="https://forums.audiworld.com/tt/msgs/1443336.phtml">https://forums.audiworld.com/tt/msgs/1443336.phtml</a</li></ul>
'ConcertI' H/U
<img src="http://mk1tt.montebellopark.com/images/blitzipod.jpg">
<img src="http://mk1tt.montebellopark.com/images/blitzipod2.jpg">
Added in the correct iPhone connector cable, it charges the iPhone as well as provides the input to the H/U
Modified this original iPhone USB base to work with the new 3G iphone, it's pretty easy to do.
<img src="http://mk1tt.montebellopark.com/images/iphonebase.png">
Added in a 12VDC USB charging adapter as the 3G iphone will not use the FireWire charging circuit. Wired the USB charger to the switched ignition. Result is a solid base for the iPhone, it charges and passes the line--outs of the phone to the input of the H/U/
Bonus: when the phone rings, you can hear the ring thru the car speakers.
<img src="http://mk1tt.montebellopark.com/images/iphonebasea4.jpg"><ul><li><a href="http://www.discountcarstereo.com/detail.aspx?ID=1170">Buy this</a></li></ul>
