If the rear had a wider track than the front>>>
Would the front end push too much in turns?
Thinking about 20mm rear spacers and 10mm fronts?
Would it effect the handling ina negative way?
TIA...P.S. have a 19mm sway on the 225.
so if you want to "line up" front and rear, you'd need approx 8mm more spacer for each rear wheel than fronts...doubt 10mm per wheel would pose any handling quirks. I ran 8mms, rear only, on my Jetta and the handling of that car was incredibly improved with susp upgrades. I also had the 8's on before upgrades and never a single problem. Mk4 rear tracks are .8" less than fronts.
<center><img src="http://pictureposter.allbrand.nu/pictures/zgtt/tt+pics/Rearat+modshack.jpg"></center><p>it handles fine as is. Tweak with tire pressure if needed.
Normally the wider stance would cause the car to understeer, or push into corners. However, your Neuspeed rear bar compensates for this already. Going a little wider stance in the rear would probably still give you decent at the limit handling.
By the way, I don't know that I'd go with spacers in the front after looking at your pictures.
